3D LINES TO 2D LINES
Thu Jan 26, 2017 11:18 am
by pilot_n7731p
i AM HAVING TROUBLE WITH A FILE THAT i IMPORTED A DWG FILE. i THINK IT IS A PROBLEM WITH 3D LINES. IS THERE A WAY TO CHANGE 3E LINES TO 2D LINES.
Re: 3D LINES TO 2D LINES
Thu Jan 26, 2017 12:59 pm
You can get the 3D Line Convert Macro from the
Datacad Website.
Fri Jan 27, 2017 9:38 am
The step you may need to do before using the 3D Line Convert, is to change the Z Base and Z Height to 0 for everything. Then when you use the 3D Line Convert, all the 3D line will be converted to 2D lines. The reason is the macro won't convert 3D line that have different Z heights at each end; only 3D lines that are all level at one Z height.
