I have a certain hatch type that shows the correct scale when drafting but displays differently in scale (smaller) in the PDF view and the plot menu. I've checked all of my settings and scales and I can't seem to correct this. Help?
I would check to see if you have Lock Scale toggled on or off for that hatch? Is the plot scale setting in the drawing view the same as the plot scale for the sheet?
This what I have setup.
I'm trying to add a couple of images to this post, but don't know how.
When you are typing a post, look down below, the is an Options tab, and a Upload Attachment tab. Click on the Upload Attachment tab, and then select Select file button. Browse for your image, and upload it.
Then, you put the cursor on your post and I think it says "place inline" - that should put the code for the image in your post. Click the Preview button, and you should see it. Repeat for additional images.
Users browsing this forum: No registered users and 98 guests
