Hello:
Two things (at least) to try: increase the Refresh rate. This also assumes that you are using the INF file for that model monitor -- if it says Plug N' Play or Standard, thne you should get the Samsung INF file; either from the CD-ROM or from their web page.
The second possibility is to change the grays to a slightly different tone -- it may be that will improve things, since you are not (apparently) seeing this issue on other colors.
