Installing fonts
Tue Nov 14, 2017 10:20 am
by 2mackids
Hello,
I have a client who uses a particular TTF for his text. I tried copying it into DataCad fonts but it doesn't show up as an option when I go to select font style in the program. He suggested that I install them into the Windows fonts but I don't have any luck doing that.
Any suggestions?
Re: Installing fonts
Tue Nov 14, 2017 12:56 pm
Just copy and paste the TTF file into the C:\Windows\Fonts folder and reboot.
Fri Nov 17, 2017 5:23 am
by Ted B
I use a rather elegant Architect's-handwriting style .ttf-font for my construction documents. The last time I emailed an exported .dwg drawing-file to an engineer, they needed the .shx-file as-well to upload the fonts I use in addition to the .ttf-font file. I have no idea what it is, but it was generated when I exported my Datacad-file to .dwg-format, ...and it worked.
I'm not computer-literate, I just play-along.
Fri Nov 17, 2017 12:08 pm
Ted B wrote:I use a rather elegant Architect's-handwriting style .ttf-font for my construction documents. The last time I emailed an exported .dwg drawing-file to an engineer, they needed the .shx-file as-well to upload the fonts I use in addition to the .ttf-font file. I have no idea what it is, but it was generated when I exported my Datacad-file to .dwg-format, ...and it worked.
SHX files also can store linetype definitions and information about complex shapes that live in the drawing.
Mon Dec 04, 2017 3:59 pm
by artmanvt2000
As an alternate method to Josh, you can also try the following.
Close Datacad
On a Windows 7 or 10 computer go to your start menu -> type in "Fonts" -> your Fonts Control panel should open -> open the folder with the new font -> drag the font file to the Fonts Control Panel -> Windows will load the font.
Open Datacad, you should be able to find the font in the text dialog box.
Wed Jan 17, 2018 5:55 pm
by melina
DCAD is not recognizing a font that I installed a couple of years ago and have used in other applications without issue. (Only recently decided to use in Datacad)
After investigating, this font is an open-type font (even though it came with the ttf extension). Will dcad normally recognize such fonts?
Wed Jan 17, 2018 6:10 pm
by David A. Giesselman
melina wrote:DCAD is not recognizing a font that I installed a couple of years ago and have used in other applications without issue. (Only recently decided to use in Datacad)
In a word; Nope. Open-Type fonts are not recognized nor supported.
Thu Jan 18, 2018 9:42 am
by melina
okily dokily
Wishlist item???? Others can say whether it is worth it.
Meanwhile, hope that info helps others.
Thu Jan 18, 2018 3:14 pm
David A. Giesselman wrote:In a word; Nope. Open-Type fonts are not recognized nor supported.
Hmmm I have several OTF fonts that I use just fine?
Fri Nov 22, 2019 4:37 am
by Ted B
Apparently some .OTF fonts have .TTF versions embedded within them.
