I've tried opening two old .dc5 projects in 11.08, and the GTV's do not appear properly. The size of the selected GTV is correct, as well as any clip cubes, but the layers that are suppose to be in each GTV are incorrect. The layers in each GTV are the same layers listed in the first GTV. This happens on two different machines. Anyone else having this problem?
Mark Rupsis
Rupsis Associates Architects. P.C.
Joined
Thu Mar 03, 2005 8:01 am
Location
Bolingbrook, Illinois
Also, this only started after installing 11.08. Didn't have any problems with this previously.
Mark Rupsis
Joined
Location
My first thought is to make sure that “Layer set” in the S4 position is turned on. Hopefully, it’s something minor like that.
Brian Engebretson
Joined
Mon Feb 14, 2005 5:23 pm
I can confirm that.
It is loosing the GTV from DC5 files.
Rank
International Distributor
Joined
Mon Feb 14, 2005 6:16 am
Location
Porto Alegre • RS • Brasil
Now that I go back and try an old DC5 file, it doesn’t work for me either. So much for the easy solution. I’m sure the gang will be working on this one soon.
Brian Engebretson
Joined
I can confirm this error. We have identified the problem and will be posting a correction as soon as possible.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com Providing thoughtfully crafted, software bugs to the DataCAD community since 1984.
Rank
Chief DataCAD Troglodyte
Joined
Thu Feb 10, 2005 4:30 pm
Location
DATACAD LLC Programming Valhalla
I didn't if everyone had tried using ctrl+F12 for the "old named views". I hope this is of so help.
Arthur Wood
CADD Manager
EH Danson Associates
St. Johnbury, Vermont
Joined
Tue Mar 08, 2005 7:55 am
Location
St. Johnsbury, Vermont
Users browsing this forum: No registered users and 71 guests
