#75015 by GARY247
Fri Oct 12, 2018 9:21 am
I have an attribute symbol that is a circle with a letter or number in it. Is there any way to position the letter or number inside the circle so that it's position stays centered if you rotate the symbol?
#75016 by Roger D
Fri Oct 12, 2018 9:36 am
If you set the text alignment to be Middle and Center, and when placing the symbol make sure "Fix Text" is on, you should be able to rotate and or Dynamically Flip the symbol any direction.
Note, some fonts do this better than others. Font ArchD seems to work for me and my door numbers.
#75017 by joshhuggins
Fri Oct 12, 2018 10:36 am
TTFs usually work better for this than the SHX fonts.
Users browsing this forum: No registered users and 97 guests
