#75086 by Neil Blanchard
Fri Oct 26, 2018 10:06 am
Hi,
We recently got a change (I think) in the way that 1-Line Trim works. The top lines in the DcadWin.INI [General] section:
Code: Select all1LineTrim By Entity=
; Controls the behavior of the Entity toggle in 1LnTrim.
; If TRUE, Entity is automatically reset to on.
; If FALSE, Entity is automatically reset to off.
; If blank, the Entity toggle will retain its last status.
My 1-Line trim shortcut is:
Code: Select allY^;^F9^F4^$^$^
//1-Line Trim
With the 2 $ symbols at the end, it used to pick the trim line, and the outside - but it no longer works. How do I get it working again?
#75087 by Roger D
Fri Oct 26, 2018 10:38 am
I use
Q^;^1016#^F9^F4^$^$^
\\ Q- Trim to one line, 1016-One Line Trim by Entity On
Users browsing this forum: No registered users and 116 guests
