Contour search with arcs
PostPosted: Fri Nov 09, 2018 2:03 pm
by dmartens
When are we going to be able to do a contour search with arcs in the boundary and have it work?
Dan
Re: Contour search with arcs
PostPosted: Fri Nov 09, 2018 2:11 pm
We can now, but the arcs have to be perfectly cleaned with adjacent lines / arcs for it to work. An old wish of mine is if the snap miss distance could be used a sweep to help jump minuscule gaps that would help contour search complete when things are not cleaned 100%.
PostPosted: Fri Nov 09, 2018 3:46 pm
by dmartens
I repeat my question then. It has been very frustrating (and today didn't help) every time there is an arc involved to have to manually select the boundary. I don't understand why this doesn't get fixed.
Dan
PostPosted: Fri Nov 09, 2018 4:01 pm
dmartens wrote:I don't understand why this doesn't get fixed.
Because curved geometry is crazy complex. :lol:
PostPosted: Fri Nov 09, 2018 4:08 pm
There was a polyline macro (within DCSprint Ln2Pln) that allowed one to create polylines by group, color match and it had a miss distance so if they did not match up, it would still create the polyline.
Sometimes I have been able to use hatch/SFB Fill/boundry/contour and it will create the hatch even with a arc that is off by 5/32" at each side (just tried it). If that works, then you double click on the polyline (what an SFB Fill is) is turn off the Fill and you will have your polyline.
A few extra steps, but you get what you want.
PostPosted: Mon Nov 12, 2018 8:11 am
I wonder if when the search process comes to an arc, the center and included angle are "known" in the drawing database - that this would be like any straight line vectors?
