Removing printers
Tue Nov 20, 2018 7:40 am
by Glenn Curran
I'm trying to remove redundant printers from DCAD20, but although I have removed them from Windows 10, they still appear in the DCAD printer dialogue.
I'm on Windows 10, Parallels 14 on iMac.
Thanks in advance for any advice!
Re: Removing printers
Tue Nov 20, 2018 8:34 am
Hi Glenn,
Did you restart DataCAD after removing the printers? Or, maybe restart Windows?
Tue Nov 20, 2018 10:07 am
by Glenn Curran
Hi Neil,
Thanks for responding. Yes, I've turned Windows and DataCad off and on. It's not a big problem, just a bit irritating to see the redundant printers listed. If I start to lose sleep over it, maybe a reinstall of DataCad is the only solution!
Regards
Glenn
Tue Nov 20, 2018 3:51 pm
The only thing I can think of, is that OSX and Windows are each installing them? Maybe running CCleaner in Windows?
Fri Jan 25, 2019 2:04 pm
by The Canuck
I run parallels as well, and I am going to guess that maybe under the configuration for "shared printers" you have selected "share Mac Printers with Windows" (or whatever you called your copy). I do not have that box checked, and it has helped me keep things a little cleaner.
