I have a drawing that continues to crash and when it does it shows the following. Internal Diagnostics fault 28 error from 808 It started when I tried to delete helplines manually a week or two ago and has got progressively worse until today I am not able to move items between layers I have tried to repair the drawing but to no avail Any ideas please
Joined
Mon Mar 14, 2005 10:52 am
Location
Elveden, Suffolk, England
Have you updated to the latest version of DataCAD? The early versions with Helplines, had some issues when erasing them.
Joined
Fri Feb 11, 2005 11:24 pm
Location
Maynard, MA, Eaarth
Thank you for your assistance Neil I am using the most up to date version
Joined
Location
Open a new blank file and then try File, Import and then select the file you are having issues with. Close and save the file and see if that works.
Thanks! - Josh
Do. Or do not. There is no try. Josh's Digital Downloads is come back
online soon. Stay tuned.
(soon is a relative term)
Joined
Fri Feb 11, 2005 5:44 pm
Location
Absolute Zero, California
Josh Opening a new blank file using File, and Importing the file I had issues with has worked. All now fully functioning. Regards Tony
Joined
Location
Users browsing this forum: No registered users and 126 guests
