I friend who I used to work with is drafting with v11 and having an issue with one file. I'm on the latest greatest DataCAD and do not see the issue. When he zooms into the field, at some point when not terribly close (a 4' distance is visible on screen), his search circle on the curser (set to 20, line type set to solid, spacing set to 1') goes to weird shapes, rectangle on one side, trapezoid on another side, long skinny rectangle to one side. When his search circle changes to this other form, he is no longer able to search or snap to anything.
The file can be downloaded from: https://brennfoerderarchitects.sharefil ... 7fe9f40ea8
An image of his screen and mine demonstrates the difference. Sorry about the dust on my screen
His file, his screen
His file, my screen
--just wandering-
