When using object viewer I just get few small dots
PostPosted: Mon Jul 15, 2019 5:25 pm
by gehlen designs
When using object viewer I only get a few small dots instead of the house in full view I thought it might be because I have an object way out in space but can't seem to get the view of just the house.
Anyone have any suggestions
Frank Gehlen
I did find the problem I did have 2 objects out in the middle of no where sorry to bother every one
Frank
Re: When using object viewer I just get few small dots
PostPosted: Wed Jul 17, 2019 1:30 pm
by dmartens
Go to move, select all the objects in the model and once highlighted hit your viewer key. This should bring up just the model in the viewer. Then you may be able to determine if there is something way out in space.
