Program Preferences Issue
Tue May 19, 2020 12:44 pm
by BEMArchitect
Went to tweak some program preferences and get this. See attached picture.
What is going on and how do I fix please?
Re: Program Preferences Issue
Tue May 19, 2020 1:37 pm
Have you tried to reboot the computer?
You could also do a install/repair on the program
Tue May 19, 2020 2:04 pm
by Mark F. Madura
"Unable to read message from message file" indicates the corresponding string for the label was not found in either DCADWIN.lbl, DCADWIN3.lbl, DCADWIN.msg, DCADWIN3.msg, or DCADWIN.mnu. This usually occurs when new lines are missing from the end of these files. Make sure you have the latest version by going to Help, Check for Update...
As Roger indicated, you can also try re-running the installer, DataCAD18Setup.exe, and performing a Repair install if the latest version is already present.
Tue May 19, 2020 5:38 pm
Also make sure that in the Pathnames tab of the program prefs that the Messages and Labels path matches where the files that Mark mentioned are located for your current version, typically it's
Support Files\Messages and Labels\
Wed May 20, 2020 11:52 am
by BEMArchitect
Thank you guys a lot! Ran the installer again, repair mode, and it fixed it.
Appreciate it very much.
