Heres a funny problem that only occurs in Version 11.08. It does not happen on our machine that runs V11.06 or 11.07. I'm wondering if it is a glitch in V11.08
I have a file that includes nested xrefs. Some of these nested xrefs include text and have been mirrored, using the "fix text" toggle. But the text appears backward in the nested xref. In previous versions there is no problem but in V11.08 the text appears backward.
Here the sequence of assembling the drawings. :
> Base file with text ( a bathtub interior elev)
> Insert the bathtub elev, as an xref, into a larger wall elevation, and then mirror it. No problem so far.
> Insert the larger wall elevation into a third "plot file" Now the bathtub is a nested xref. Here the text appears backwards.
Again - no problem in V11.06 and 11.07.
BEN
