symbol scale gigantic
PostPosted: Mon Nov 01, 2021 6:28 pm
by Bob Urbanek
This may be a simple fix, but I can't find it. Opened up an old drawing in V19, tried to edit it. Tried to install a symbol, and it comes in at a huge scale.Same thing with any symbol. Tried to fix it in the browser but no luck.How do I fix this? I tried opening the drawing in V22, but got the same result.
Thanks, Bob
Re: symbol scale gigantic
PostPosted: Mon Nov 01, 2021 6:35 pm
While inserting the symbol, check if Symbol Scale is turned on if you do not have your symbols setup to use Symbol Scale.
PostPosted: Mon Nov 01, 2021 6:46 pm
by Bob Urbanek
Thanks for the reply, Josh. I have tried it with symbol scale on and off . Also symbol scale by folder on and off. Tried both on and off too? Can't figure it out.
Bob
PostPosted: Mon Nov 01, 2021 6:49 pm
Is the enlargement set to more than one?
PostPosted: Mon Nov 01, 2021 7:37 pm
by Bob Urbanek
It is set to one.
PostPosted: Mon Nov 01, 2021 8:09 pm
by Bob Urbanek
I think that it is drawing specific.
PostPosted: Mon Nov 01, 2021 11:53 pm
by Bob Urbanek
I have determined that it is only affecting that one drawing, and that it comes in 50 times larger.
