Saving the drawing as a PDF
Sat May 28, 2022 11:24 am
by esme103
I can't remember how to save the detail or drawing as a PDF. I am using a new computer with Windows 11.
In advance, thank you for your advice.
Re: Saving the drawing as a PDF
Sat May 28, 2022 1:19 pm
1. If you hit F1-Print, then select option "Save" and then select the pdf format.
2. If you hit F2-Batch Plot, then you can select the Save As PDF option.
or
3. If you have a pdf printer set up (PDFill, BullZip, Microsoft PDF, etc) then you can print using that printer.
