The GTV's have some real problems with undo and redo-ing properly. I've come across the problem your having, and it seems if I close Datacad, the problem goes away.
Here's a video clip where it shows when you change to several GTV's then undo the several GTV changes, then redo them, on the redo process, some of the layers (not all of them) that get turned on in the redo process of the GTV's do not get turned off when the next redo that should in the next GTV in the sequence. When your done with the redo steps your screen looks like everything is o.k., but it's not, if you regen the screen, you find those layers that were not properly turned off. This has got me in trouble a few times. I didn't realize that those layers were turned on, and started editing, did some stretching, and then those hidden entities started to show up ad they got "in the way" while I was editing. So I had to undo all the way back to the farthest point before I started redo things. So I lost a bit of work. This should be addressed in a patch, as it can cause some damage, JOGO.
Undo Redo Bug
