Hi,
I have been working with DataCAD now for about 3 months and i like it a lot.
I have a problem with symbols.
I first inserter a symbol and then mirrored it.
I then tried to save that mirrored symbol as the same symbol through the symbol browser menu.( i now understand i should have exploded it first before saving it)
This coursed the program to completely shut down and when reloading the drawing I get the message: DataCAD (internal diagnostics) fault 10 Error from 736.
Now when i do get the file up and running through the back up file the symbol that i accidentally saved the mirrored symbol is not in the symbol browser.
When loading other drawings the symbol is shown.
How can i get the symbol back as cutting and pasteing from another drawing will not work, as it insert 4 small crosses instead of the tile symbol required.
Has anyone had this problem before and what can be done about it, this is the first glitch since i started using datacad. Apologise if this has been reported before.
Regards
Bruce.
Regards
Bruce.
