Hi Peter:
You can't do this from the LM -- but you can do it from the Directory menu!
From the Directory dialog, click on To File. The problem is that there is no way to control where this output file is created (hint, hint
), but the way to find out where the file was made, is to click To File
again and and make a note of the path. The file is called YourFileName.DIR, but it is jsut a text file that can be opened by NotePad and printed or whetever you need to do with it.
