No Wonder DWGS get corrupted!!!
Check this kids!! When hatching, you click first point and then second, as you are about to click third, you decide you dont' want to hatch....so you right-click couple times and you are out of that command. Even the Hatch is cancelled.....or is it?
Do the above in a open dwg area, once you cancel....select the "Erase" command and rubberband select the place where you drew.
You will find a an incomplete polygon....the naked eyes cannot see!!!! Thus giving us corrupted data often!!! Arrrgghhhh!!!!
