Line Type Manager
Posted: Sun Sep 03, 2006 12:35 pm
Where can I find information on how it works?
I checked the help file, the update help and found nothing unless I over looked it.
I am having problems defining insulations, for example R-38 which should have a thickness of 12” but when I created the line type (from a drawing scaled at 3/16), I gave it a spacing .6 (so far so good), but when I go to test it by selecting it from the line type menu and bring it into the same drawing it was created from (did not change drawing scale), it comes in much smaller. When I use the “Identify“ command to check it, it indicates the spacing to be 6” (the same as original one on the drawing which visually is correct)?
