This may be a stupid question and there probably is an obvious answer, but is there a way of loading more True Type fonts into DC11? All suggestions gratefully received.
DataCAD uses the Windows TTF fonts.
You find the Windows TTF fonts under //windows/fonts.
If you copy new TTF fonts into this directory, you will find more TTF fonts in DataCAD and in Windows.
Martell is correct. Also, you are going to want to limit the quantity of use of TTF fonts in drawings, because they are a lot slower to refresh than the vector CHR fonts.
