Just got Dcad 11.
In Plus I was able to see exactly the shape and angle of the hip or valley where two roof planes meet - a joint visible only in shaded view -and stretch the roughed-in planes to that exact junction. I would snap the view to one plane, shade the view, then draw a 3-d line tracing that joint. Then when the shading was off I would stretch the plane to that 3-d line. I did that to each plane in turn.
PROBLEM: 11 freezes the workspace when it shows a shaded view. Expecting apparently that this is some big wonderful view that you want to make into a bitmap, apparently . The problem with the frozen workspace is that you have to right click and tell it to go away before you can draw the required 3-d line. But at that point you have no shaded view to trace.
QUESTION: Is there any way to turn off the freezup. And / or to draw upon a shaded view?
