Hi, I have a drawing file that for some reason won't open on version 10 (where it was created).
DataCAD (internal diagnostics) fault 43 Error from: 736
This is all the info I have on it, except that it does appear to display the drawing correctly prior to crashing. I've made sure that all .$$$ and .swp are gone. How can I parse this error? Does it mean that line 736 is the location of the problem? Does it have to do with the default view? Can I hexedit the file to at least get some of the entities back? It was the final version of the project, so I'd really like to be able to access it.
