dannac wrote:Are these the same programs/macros ?
If not, any advantages to roof builder macro ?
Thanks
Danna
Hello Danna,
Roofit is a macro that ships with Datacad. It is good for doing simple roofs (i.e. all plate heights ar the same).
RoofBuilder is a seperate macro written by People Software (I beleive), and is pramirly a MODELING tool
RoofBuilder excels at MODELING much more complicated roofs. The catch is that you already have to have a 2D ROOF Plan to work from - RoofBuilder is NOT a tool to draw a roof with, it is a tool to help MODEL your existing roof plan. I also use it as a check to make sure that my roof is correct - it becomes obvious very quickly if you have made a mistake on your 2d Roof plan, once you model it with Roofbuilder.
Aaron Ben-Avraham
Atlanta, GA
