Just sent this in to the DBug forum. Thought I'd try here also.
Hope someone can help me sort this out. This is only happening in one particular drawing file (V11.06.00).
When I lay out my MSP sheets in the plotter menu, I arrange my details on the sheet, name them, go to the plot preview, everthing shows up fine, but when I return to the sheet later, the sheet appears to be blank. If I do a plot preview of that sheet, everything shows up fine in the preview window. I just can't go back to that sheet to add or change details because I can't see them! Gotta be some setting I screwed up, but I've been all over the menu and can't find a thing. Any help much appreciated. You know the routine, only happens when you're on a tight schedule. TIA
