Saving oversized drawings to plot file
Sun Apr 03, 2005 9:00 pm
by gmartin212
I have a HP220 design jet that plots a max. 24"X36" sheet. I have a drawing that will only fit to 30"X42". I need to save it to a .plt file at this size to e-mail to my printer. But, because it exceeds the limits of my printer it will not let me save it at 30"X42" size. Is there a way around this? Thanks!
Sun Apr 03, 2005 9:09 pm
Hello:
You can install the driver for the plotter that the service uses -- and set the port "To File". That way you're sure to have the right paper size. Or, you can install a "generic" driver like the HP 750C and do the same sort of set up.
Re: Saving oversized drawings to plot file
Sun Apr 03, 2005 10:16 pm
by Nick Pyner
[quote="gmartin212"]I have a HP220 design jet that plots a max. 24"X36" sheet. I have a drawing that will only fit to 30"X42". I need to save it to a .plt file at this size to e-mail to my printer.
This is akin to other recent posts. I submit you would be better off sending a PDF.
Rather than use the built-in PDF facility, you can use PDF995. This has the advantage than you can specify any paper size, even ones you cannot print yourself. PDF995 is a freebie and looks just like any other plotter to DataCad.
It solves any pentable or line density issues at the same time and you get the WISYWIG under DataCad.
Mon Apr 04, 2005 6:01 am
Hello:
Nick Pyner wrote:This is akin to other recent posts. I submit you would be better off sending a PDF.
I agree a PDF is the better method. You can install the driver for the model the service uses, and then use the plot preview "Save As" to get a PDF. I have not used the PDF995 very much, but I know that the internal PDF writer can do batch plots; creating a bunch of PDF's all at once.
