We've just noticed some strange occurrences with pdf printing to 11x17 and wonder if anyone has had the same problems. running datacad 10.
When we print direct from datacad, the printed copy looks fine, but when we save as PDF then open it in Adobe the printed version is very light.
We've checked the pen tables are only printing in black.
Any ideas?
I don't know if this is an answer to the situation, but I find also that the line width of a pdf will vary depending on the printer setting at the time of printing from the pdf. A very fine, or high quality setting will require more printer memory, and if used will yield a lighter print.
