For some reason my Clip It macro is not working as it always has in the past. Typically in my Key Plan I will hatch the tenant space with ansi31 or the like. I make sure that Search Hatch is toggled on in the Object Snap menu and ther use Clip It to remove the hatching that is underneath my label.....for example Proposed Space..... Clip It is not doing this anymore. Have I missed a toogle or something?
The hatching isn't associative is it? Clip it won't cut out associative hatching. If it is you will need to explode the hatching or rehatch as non-associative.
The only other thing I can think of is are you set to the hatching layer? Doesn't Clip It need to be on the layer of the entities it is clipping?
Since voids have been possible on associative hatching I have not used Clip It much. I would hatch the area using associative hatching then draw a polyline rectangle around the text and then make it a void of the hatching.
