#22227 by wbeacham
Wed Apr 04, 2007 8:17 am
What have I done. THe default angle in a drawing has changed from 0 to 90 degrees. I've had this happen before and I can't remember where to reset it. I changed the start angle but the default angle when I copy is 90 degrees. Help please.
Bill Beacham
#22229 by Neil Blanchard
Wed Apr 04, 2007 8:24 am
Hello Bill,
You probably have the cursor rotated 90 degrees, with the Tangents function. To get it back to normal, hit the B button, and if the F3 Cancel button is visible on the menu, select it to cancel, then right click out to the main menu -- and that should do it?
#22230 by wbeacham
Wed Apr 04, 2007 8:28 am
That was it, I had to undo the other stuff I did after that but it works fine now. Thanks Neil , I've done that a thousand times over the years and I always forget how to change it back.
Users browsing this forum: No registered users and 102 guests
