Ok. Let me see if I can explain this one.
I have recently purchased a new Canon IPF600 large format printer/plotter. This model has a automatic roll feed and a cassett feed.
Most my plots are send to ARCH D size. However on occassion I like to plot a 11x17 check print. Unfortunately I cannot take advantage of DataCads check plot feature in the plotting comand.
This is where it gets complicated. When I try to use this feature my new plotter won't let me convert from ARCH D to 11x17 due to the cassett not originally supporting the ARCH D size print. I have to save as a pdf and resize the drawing this way.
On a long shot. Has anyone else run into this problem. With either this plotter or another. And whats the solution if any. Converting to pdf takes alot longer and not as easy
Thanks
Thanks
David Siniscalchi
New England Home Designs
Monson, Massachusetts
Tel: (413)283-4860
Tel: (413)283-4860
