I wanted to check out the purge command, as I am currently using V.10, to see how it works. I opened 2 DC5 files and was going to compare the purge command with the layer utility command. As I was purging one of the files, saving it as an ACE file, the program immediately crashed!! I then tried to open the file i had yet to purge, and it would not open. Come to find out, V.12 will not open any of my DC5 files!! I restarted my machine, and that still did not work, any ideas??
Try clearing out your Datacad Temp folder, open your DC5 file, just close and save the file as a AEC first and then reopen it and try your purge. Are you trying the purge under the file menu or using the automatic purge from the ini settings file when you close the drawing? Are you opening the dc5 files from your harddrive or maybe a CD? Let us know
Thanks! - Josh
The Cad Man wrote:I wanted to check out the purge command, as I am currently using V.10, to see how it works. I opened 2 DC5 files and was going to compare the purge command with the layer utility command. As I was purging one of the files, saving it as an ACE file, the program immediately crashed!! I then tried to open the file i had yet to purge, and it would not open. Come to find out, V.12 will not open any of my DC5 files!! I restarted my machine, and that still did not work, any ideas??Are the DC5 files that fail to open greater than 1MB in size? The free trial version has a file size limit.
With regard to the file that opened but failed to purge, at what point during the process did it fail? Did you receive an error message?
Mark Toce
DATACAD LLC
DATACAD LLC
Both files I opened were approx 6MBs, and they opened fine the first time (opened from a drive on our server). Once I chose Purge, from the file menu, and clicked save as AEC it crashed. It does let me open DC5 file less than 1MB, strange how it allowed me to open larger files the 1st time around though...
The Cad Man wrote:Both files I opened were approx 6MBs, and they opened fine the first time (opened from a drive on our server). Once I chose Purge, from the file menu, and clicked save as AEC it crashed. It does let me open DC5 file less than 1MB, strange how it allowed me to open larger files the 1st time around though...Not sure how it could have opened a file larger than the limit...
Could you send me a copy of the file that crashed when you tried to purge it? Send it to techsupport@datacad.com. Thanks!
Mark Toce
DATACAD LLC
DATACAD LLC
Hello,
If you plan on working on the DC5 files again in v10, then you should probably not use v11 to purge them -- you can only use DWG export to open the files again in v10.
I would use the Layer Utility macro in v10, instead!
Ulitimately I plan to do everything in V.12, once it is released I was just concerned that there was a bug with the purge command.
The Cad Man wrote:Ulitimately I plan to do everything in V.12, once it is released I was just concerned that there was a bug with the purge command.I sure hope there isn't. And if there is, I'd like to find it now, before we send CDs out for duplication...
Mark Toce
DATACAD LLC
DATACAD LLC
Hello,
Okay, I geddit now. In v11 and v12, you do not have to manually purge the file -- it happens automatically when you open and close the file.
Thats convienent!! Do you think there will be any major issues going from V.10 to V.12?
Users browsing this forum: No registered users and 121 guests
