I have a drawing that has been saved out to a new name a few times. It tells me upon booting it that it has orphaned reference files. However, when I then go into Insert and Reference File Management and then Orphans, the file box is empty. So, where are the orphans (sleeping no less) for me to then redirect to the correct location? Or, how do I fix something to make the false orphan note go away?
If the XRef's have Nesting turned on, and if there are Orphaned XRef's in those files, then you can either turn off nesting (if you don't need it) or fix the orphans in the other files.
You have to go back to all the original Xrefs and open them. That is where you will find your culprit of the Orphan Xref. Once you find it and redefine then close all drawings and open as normal and all shoud be OK.
