I used the smart walls and doors plus windows were inserted. Great!!!! in Object Viewer but when I send it to Sketch-up the walls go to being just lines not the 8' ones I used? What could be up with that. The roof fit macro works great and it tranfered to Sketch-up perfect
You need to use the Extract 3D command in the Tools pull-down menu to extract the 3D information form the smart objects, then send that information out to SketchUp. For more information, see the following topic:
http://forum.datacad.com/viewtopic.php?t=5501
