I am assuming from the Undo & Redo at the beginning that those are custom toolbars. You should be able to copy the bmp's that make up the icons from your v11 Support Files\Toolbars\ folder.
AJ Blasio (aka Tony)
Windows 10
Intel CORE i5
8GB Ram
Windows 10
Intel CORE i5
8GB Ram
Greetings,
Is that a custom toolbar, or a standard one?
Standard I believe, I downloaded the full blown test drive for rc24, not the update, and installed it. Opened up the program and noticed they were missing.
Hello,
If you drag it out into the drawing area, you should be able to see the title of it.
The Cad Man wrote:Its name is "Icon I:DCADWIN"That's one of the toolbars from DataCAD 10 or prior. The bitmaps for it should have been copied from your DataCAD 10 installation into the Support Files\Toolbars sub-folder of the Test Drive installation. You can try manually copying them using Windows Explorer.
Alternatively, you can select Tools\Program Preferences, go to the Interface tab, and select one of the toolbars included with the Test Drive instead of DCADWIN. I typically use the Draw and Edit toolbars, which should have most of the same buttons as DCADWIN anyway.
Mark Toce
DATACAD LLC
DATACAD LLC
GREAT THANKS, MAKES SENSE SINCE I AM CURRENTLY USING V.10.
Users browsing this forum: No registered users and 93 guests
