How do you set wall widths? The wall type manager has a default setting of 114.8, with no option of changing the width. The wall display attributes have two spacing settings, which seem to have a will of their own, and why two? There is supposed to be a Wall Style Manager - not under my 'architect' menu ,... is it lurking somewhere else? It looks nice in the manual , but where is it?
In the Line properties click on the line drop down box and select 2, then edit the 114.80 dimension
I hope this helps.
