After upgrading to Windows Vista 64bit edition it appears that the native display list does not work. I noticed a slow regen when moving around a drawing and decided to uncheck the display list option to see if there would be a difference but there was no change. Anyone else noticed this?
Hello,
I have used v12 in 64bit WinXP, but not Vista. I had no issues with either the normal 32bit Display List, or the 64bit optional Display List. Have you tried the 64bit DL? If you look in the DcadWin.INI file, in the [Display List] section, and add or modify the line to:
DoublePrecision=TRUE
Also, I would check for the latest video driver. How much RAM is in this machine?
