Bruce111 wrote:I seem to be getting a problem with groups. I create a group of about 2600 entity's and then copy and paste the group into the same drawing and all is well. When I come to move the group it is randomly split and does not move as a group. Can anyone confirm this. Is there a limit to groups now?
Many thanks
I can confirm this but only when using an old v11 default file. If I create a new v12 non-default file the copy and past seems to work properly.
With the V11 file, I created 3 lines individually and then used the group command. I also tried creating 3 lines chained together as a single group. I then copy and past the 3 lines into the same file. When I try to move the new 3 lines as a group I get the first two only.
