Hi all,
Just wanted to ask how everyone will be accomplishing 2D Construction documents using Dcad 12 Smart walls & other smart functions. In Dcad Plus, there were many instances where I would have to suplement smart walls with 2D lines & entities in order to make the the construction documents look as they should. I would think that I'll run into the same issue with Dcad 12.
I've extracted 2D elements using Dcad 12 extract function. I noticed that 2D elements are saved to an assigned layer. If I perform extract function more than once, the 2D elements are not overwritten but are saved to new assigned layer.
Given the way 2D elements are saved I would like to ask forum members how they would incorporate ( or not ) the 2D "stuff" into their views & multi layouts.
I do like the ability of being able to fill in the gaps so to speak with normal 2D entities.
Looking forward to hearing how all of you will manage the 3D to 2D drawings. Hoping to learn from everyone.
Giuseppe
Giuseppe
