#25558 by Jon C. Hubart
Wed Jun 27, 2007 12:29 pm
Are you asking to change one entity to match the properties of another entity, including layer?
If so you can use the following string to create a custom keyboard macro to do basically this.
Code: Select allO^8#^S6^S7^S6^F1^$^32#^$^S0^S0^S0
//Entity nearest to cursor is changed to match the current settings
First you use "Identify" "Set all" (Alt-I) to make the entity properties your current settings then in my case I use Alt-O to set any given entity to those same settings.
In case you don't already have this set you should change Alt-I to be
Code: Select allI^7#^$^S8^S0
// Identify Set All
So its a quick ALt-I on the first entity, then Alt-O on the second entity and they will now match.
#25561 by Tamara
Wed Jun 27, 2007 12:41 pm
It works! I was basically looking for the Autocad Match Properties and this is pretty close.
#25564 by Jon C. Hubart
Wed Jun 27, 2007 1:10 pm
The "Change" menu will get you close but it does not have the option for changing layer. The keyboard shortcut is the best approach I can find.
Users browsing this forum: Google [Bot] and 106 guests
