I'm having some difficulty creating an exterior sliding glass door with a custom door type (necessitating the use of the 3D symbol) with the "jamb in" setting. As you can see below, when I toggle this setting on, the doors leave a gap in the middle. I have tried several different locations for the symbol insertion point, etc. but this always happens. And it only happens on the sliding door type. If I set it to "double" with all of the settings the same, there is no gap between the doors. It only occurs when selecting "sliding" when using a 3D symbol.
Anyone else having this or a similar problem?
Also, is there any way to modify the amount of overlap on the two sliding panels?
Tico McCready
