#25813 by pkbldr
Fri Jul 06, 2007 5:21 am
I've installed / removed DC-12 twice now, once Custom and once Complete, and have not been given the option to "copy some of my DC-11 settings and files to the DC-12 program folder automatically" as stated in "Before You Begin".
The prospect of manually adding / changing all that is not something I look forward to.
What am I missing?
Thanks for the assistance in advance.
Pat
#25817 by Mark Toce
Fri Jul 06, 2007 8:23 am
pkbldr wrote:I've installed / removed DC-12 twice now, once Custom and once Complete, and have not been given the option to "copy some of my DC-11 settings and files to the DC-12 program folder automatically" as stated in "Before You Begin".
What am I missing?
Pat
It sounds like Setup is not finding your DataCAD 11 installation. In what folder is DataCAD 11 installed? Is there a shortcut for it in your Start menu?
#25833 by pkbldr
Fri Jul 06, 2007 11:40 am
It is installed in "C:\Program Files\DataCAD\DCADWIN.exe" and yes there is a shortcut in START.
#25846 by Mark Toce
Fri Jul 06, 2007 12:20 pm
pkbldr wrote:It is installed in "C:\Program Files\DataCAD\DCADWIN.exe" and yes there is a shortcut in START.
Right click the shortcut in the Start menu and choose Properties. Does the value in the "Start In" field match the actual location of the program? Is Dcadwin.exe present in that location? Is Dcadwin.ini present in teh same folder? Does DataCAD 11 run?
#25850 by pkbldr
Fri Jul 06, 2007 12:35 pm
<Right click the shortcut in the Start menu and choose Properties. Does the value in the "Start In" field match the actual location of the program?
Yes: "C:\Program Files\DataCAD"
<Is Dcadwin.exe present in that location?
Yes: "C:\Program Files\DataCAD\DCADWIN.exe"
<Is Dcadwin.ini present in teh same folder?
Yes, all program files except drawings.
<Does DataCAD 11 run?
Yes.
#25859 by Mark F. Madura
Fri Jul 06, 2007 1:51 pm
Does your "DataCAD 11" shortcut live in a "DataCAD 11" program folder?
MFM
#25861 by pkbldr
Fri Jul 06, 2007 2:04 pm
<Does your "DataCAD 11" shortcut live in a "DataCAD 11" program folder?
I don't understand.
I have a shortcut in the START menu and on in a list of shortcuts in the system tray.
I do not have a "DataCAD 11" folder but a "DataCAD" folder in Program Files as shown.
The paths shown in previous posts are cut and pasted from the properties window under the start window.
#25864 by Mark F. Madura
Fri Jul 06, 2007 3:00 pm
In other words...
Is your DataCAD 11 shortcut located in the following path?
C:\Documents and Settings\All Users\Start Menu\Programs\DataCAD 11
MFM
#25865 by Dick Eades
Fri Jul 06, 2007 3:02 pm
I don't know about his but mine is in C:\Documents and Settings\All Users\Start Menu\Programs\DataCAD and it is bone stock just the way DataCAD installed it.
#25875 by pkbldr
Fri Jul 06, 2007 4:45 pm
No it's not.
I'll try putting one there though and see.
Thanks and I'll let you know.
Pat
#25877 by pkbldr
Fri Jul 06, 2007 5:23 pm
No Joy.
Shortcut is now in:
"C:\Documents and Settings\All Users\Start Menu\Programs\DataCAD 11"
and it does work.
One thing is good though, I've done the installation so many times now that I've memorized my Serial Number.
Any thoughts will be greatly appreciated.
Thanks and have a good weekend.
Pat
#25886 by pkbldr
Sat Jul 07, 2007 6:21 am
Windows XP Pro
#25963 by pkbldr
Mon Jul 09, 2007 7:37 pm
So, should I just call tech support?
Pat
#25965 by David A. Giesselman
Mon Jul 09, 2007 7:50 pm
Yes!
