I never had problems with my hardlock until I installed a new program on my home computer. Some type of McAffee firewall came with the program and although I personally don't like McAffee products, I just told the computer to install everything (I was in a hurry at the time). I immediately started to have problems with my hardlock along with some other USB devices. I seems that the new firewall was denying access from the USB devices on occasions. After I uninstalled the firewall, everything worked fine again. For those that have hardlock problems and use a firewall, maybe you could look at your firewall settings to see if it is causing conflicts with your USB devices.
That's some serious firewall if it's blocking USB devices
Thanks! - Josh
joshhuggins wrote:That's some serious firewall if it's blocking USB devices
Yeah, it must be. Since I didn't want that firewall anyway, I never looked into why it was blocking them.
For those that are still having problems with your hardlock, have you tried using it on another computer? That might help to narrow down the problem.
Sam wrote:Vincent- I too am having the exact same problems as you have described. Did you ever find a solution? Techsupport doesn't seem too interested I'm afraid. Thanks. Sam
Hello Sam,
No to date I have not been able to locate what is causing the problem. It is very allusive. There are days when I will loose the hardlock key many times in one session, other times it will work the way it should.
Sometimes to get the program to work without removing the hardlock, if I first launch v11 then shut it down and then try to launch v12, v12 will startup.
What I am really concern about in continually removing the hardlock for v12 is eventually I will damage it.
I am reminded of an earlier version of datacad when the USB hardlock was first used and I removed it for some reason and when I went to put it back the coding? Within the key was damaged and I had to shutdown, send the key back to datacad for them to exchange it.
Vincent
Users browsing this forum: No registered users and 122 guests
