Thank you Tony - I'd not been aware of that difference, but, sure enough there is a 15MB limit listed on the comparison table. I could split into two files, but is there a way to streamline the existing one? Are there embedded copies or is there a means to compress parts and leave this as one file? Thanks again.
Things to look for are non-associative hatching, extensive use of True Type Fonts and high polygon counts in 3D Entities. If you keep those to a minimum it should reduce things. Other may chime in with more recommendations.
AJ Blasio (aka Tony)
DataCAD 18 (DataCAD User since v5) Windows 10 Intel CORE i5 8GB Ram
Thank you Neil - helpful advice. I need to put myself on a MB diet.
I copied the file and then deleted all plan information from the second one. To my surprise, when I checked the file size of the second one (where I had deleted many layers and lots of information) it was still showing as 15 MB. So far, I've not received any more "File is full" messages though. Is there a further step to have it shown in a reduced size?
When you close the drawing window, Select Yes to save the drawing. Your file should now display the correct size in Windows explorer or in Directory when re-opened.
