Does anyone know how to create .rgb Dcad colour palettes from a paint manufacturer's colours? Thanks.
Hello Ken,
There are several color patterns in DataCAD installation. They are stored at "\Support Files" folder and are all named *.RGB.
All color patterns in DataCAD follow the RGB color table (from Red, Green and Blue), and they are limited to 255 color/tones, plus Color 'Zero'. Generaly the professional printing palettes are expressed on a different system: CMYK (from Cyan, Magenta, Yellow and Black), which allows more accurate tones control.
Any image processing software can handle both formats. I use Paint Shop Pro, but there is Adobe Photo Shop and many alike in the market.
As long as you know the correspondence for each color in the list, you can create your own color palette, like this below, the DEFAULT.RGB, opened on Notepad.
Data are organized in a table with four collumns (tab separated), in the order: Red for the first, Green the second, Blue the third and the name on the fourth position.
You can get all data from an Excel sheet exporte text-format "tab separated" and fill the file.
Please pay attention that the color 'zero' (black) is kept as the counterpart for white color, when the user chooses a white background, and you should keep the first 16 lines (15 standard colors and 'zero') for compatibility reasons to drawings created outside your installation.
Finally you're allowed actually to add 240 colors to your new palette.
To have this new palette loaded on every new drawing, is enough to load it to your default drawing file.
Hope this helps,
