#26643 by hlewis
Tue Jul 31, 2007 3:47 pm
when we write a dwg from a file with multiple x-refs, the dwg doesn't display the x-ref. Instead, a placeholder shows the path. In order to get the x-refs into the dwg, we have to change the file names in the dwg folder.
Why is Dcad not saving the x-ref files with the correct names.
For example: the file (A1.0-Composite Plan) has the files (A2.0 & A2.1-Floor Plan - Building 1) and (A2.2-Floor Plan - Building 2) x-refed in. When we export to dwg, the (A1.0-Composit Plan) file is saved, but the x-ref files are saved as (A2.0 & A2.1) and (A2.2-Floor)
We have been using long file names with spaces for years, and are just now starting to get this problem. The only thing that we are doing differently, is using more go-to-views in a single drawing. Does this have any relevance?
Brian Lanier
#26676 by Mark Toce
Wed Aug 01, 2007 9:59 am
I suspect the problem is the periods in the file names. Try taking them out and replacing them with underscores and see if that helps.
Users browsing this forum: No registered users and 106 guests
