#26744 by Morry Stafford
Thu Aug 02, 2007 9:02 pm
Just installed V12, then right to V12.01.01.01
I then opened a project developed in V11. When I went to the print sheet menu, the screen starts the screen display then immediately closes the file, all within a second or two. Any suggestions?
#26753 by David A. Giesselman
Fri Aug 03, 2007 7:44 am
Morry,
This may be due to some corrupted printer settings in that file. Try opening the file in v12 and pressing [Ctrl]+[Shift]+C. This will clear the printer settings and should allow you to enter the Print menu. You will, of course, have to re-select your printer/plotter when you enter the Print menu. However, any sheet layouts you had previously defined will still be there.
