On project sheets that were created on 11 where large numbers of reference files occur, we noticing that the version 12 sheets simply do not load on the first try (even though all drawings have been updated to 12). In opening the file, you can see the drawing screen and then right before the title sheet loads, the screen goes blank as if you closed your drawing. If you attempt to load your drawing again, you'll see the drawing not exited properly error message and the file loads after selecting okay. If you exit instead, you'll get 'Dcadwin.exe needs to notify MS message but the file loads on the next try.
This is happening on several computers - hardwired and wireless. Doesn't occur projects with reference files that were created in 12 or with drawings with only the title sheet referenced.
Anyone else seeing this same sceranio?
TIA,
Jeff
TIA,
Jeff
Jeff Budkoski
Director of Architecture
Higginbotham Design & Engineering
DataCAD v12
AutoCAD Architecture 2008
DataCAD v12
