Line type export to dwg problem
Posted: Fri Oct 19, 2007 9:31 am
When ever I export a drawing to dwg any line type other than solid looks odd. The line is there but there is a space and a dot at the end of each line.
datacad centerline
converted to dwg
Is there anyway to solve this? i convert everything to solid when i export but it is starting to confuse our engineers.
datacad centerline
Code: Select all
converted to dwg
Code: Select all
