Is there a way to have dimensions drawn in a single file using architectural scale and engineering scale?
Hello Giuseppe,
I've not noticed it before.
Unfortunatelly, today this is not possible.
I am assuming that you are referring to "Associated dimensions". If you "explode" them, you can get it, but in that case any drawing update will not benefit.
You can use only one Scale in assoc. dim. on each drawing file.
